I have TWR-K60D100M, which has PK60DN512VMD102, MCU.
Code warrior info:
- CodeWarrior for MCU
Version: 10.2
Build Id:120126
- MQX : 4.0
I created a New MQX project with, MFS,Shell,RTCS enabled.
When I build the project, I am getting an error as,
" Size of the application has exceeded the capability of this license. Contact your authorized distributor or Freescale to purchase a full version of the tools."
ofcourse, I understood the meaning. I like to know, is there anyway, to use the 3 libs [MFS,shell,RTCS] with my current license, by changing any optimization to reduce the application size?
Thanks.
Solved! Go to Solution.
Hello crond deamon,
you can reduce the size certainly. I don't know the CW limit it poses.
Why don't you try to build release target and customize optimizations, disable features in the user config which your application doesn't use. Still not the size you would like to get, start rewriting drivers you want to use.
Please follow this two links which might be quite helpful :
code size problem ,reduce the code size
Memory footprint of MQX+MSF+RTCS on MCF51CN ?
0xc0170
Hello crond deamon,
0xc0170
hey, thanks Martin. I will look into your suggestions :smileyhappy:
