adding shared component (adc + pwm)
Question asked by Francesco Prosperi on Mar 15, 2013
Latest reply on Mar 20, 2013 by Francesco Prosperi
using CW 10.3 I'm trying to configure my application to use ADC and PWM on the same pin.
I don't know if pin sharing has a limitation in my case.
I read the documentation and I know I should set the two conflicting components one as "main"
and the other as "shared", for the Pin Sharing feature to be enabled (Component Inspector Tab
in EXPERT mode).
The problem is I don't know how to set a component as shared.
Could you explain me how to do it, please?
FP
