Erasing Flash sectors in KL25 and FreeRtos
Question asked by Heron Hurpia on Mar 4, 2013
Latest reply on Mar 12, 2013 by Garabo
     I implemented successfully flash Erase and write routines as suggested in thread Erasing Flash sectors in KL25 on the Freedom Board, but when I tried to use with FreerRtos and more threads I got a message "No source available for "0xFFFFFFFE (0xFFFFFFFE)() "
     I already tried to use Cpu_DisableInt(); and taskENTER_CRITICAL(); but it didn't work. The error occurs after a few hundreds cycles.
Erase sector
     FLASH1_Erase(FLASH1Pointer, 0x1F000, 1024);
     do {
            FLASH1_Main(FLASH1Pointer);
            OpStatus = FLASH1_GetOperationStatus(FLASH1Pointer);
      } while (!((OpStatus == LDD_FLASH_IDLE) | (OpStatus == LDD_FLASH_FAILED)));
And then write the data in Flash:
      FLASH1_Write(FLASH1Pointer, FromPtr, 0x1F000, Size);
      do {
     Does someone have any suggestion ?
