i.mx6 ltib elftosb build
Question asked by frankmiller on Mar 1, 2013
Latest reply on Mar 1, 2013 by frankmiller
Greeting,
I'm trying run ltib for the first time from the i.MX6 source tarball.  I'm using Ubuntu 12.10  Here's the error I get after awhile:
Executing(%build): /bin/sh -e /home/fwmiller/Freescale/ltib/tmp/rpm-tmp.25768
+ umask 022
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD
+ cd elftosb-12.09.01
+ make
make -C bld/linux -f /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/makefile.rules SRC_DIR=/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01 all;
make[1]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/bld/linux'
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/common/AESKey.cpp
In file included from /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/common/AESKey.h:10:0,
                 from /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/common/AESKey.cpp:8:
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/common/stdafx.h:30:36: fatal error: /usr/include/sys/types.h: No such file or directory
compilation terminated.
make[1]: *** [AESKey.o] Error 1
make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/bld/linux'
make: *** [all] Error 2
error: Bad exit status from /home/fwmiller/Freescale/ltib/tmp/rpm-tmp.25768 (%build)
RPM build errors:
Build time for elftosb: 0 seconds
Failed building elftosb
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
Started: Fri Mar  1 09:43:46 2013
Ended:   Fri Mar  1 09:57:04 2013
Elapsed: 798 seconds
These packages failed to build:
elftosb
Build Failed
Any thoughts?
FM
