Kinetis KL1x and KL2x thermal/exposed PAD
lfschrickte
I can't find in the Kinetis family documentation any reference to the thermal pad connection! Is it isolated? Can I connect it to ground? Both alternatives are right?
I know it is usual to connect it to ground, but as a designer I prefer to see it written by freescale in order to be sure I can connect it. The only reference I've saw is the crystal layout guidelines in the Product Quick reference in which the Thermal Pad is connected to the ground.
Does anyone knows this information for sure? If it is written somewhere I've missed, please point me out!
Thank you
Pepe_Ruiz
Hi Luis Fernando,
The thermal pad is isolated just like you said and the recomendation is to ground it.
just be carefull with the solder
regards
/Jose
Pepe_Ruiz
Hi Luis Fernando,
regards
/Jose
lfschrickte
Thank you Jose!
I wish this information was present in the Datasheet or the Reference
Manual. Even if it is something quite "obvious", it is always nice to have
it confirmed somewhere!
I appreciate your help.
Luiz Fernando
Luiz Fernando Schrickte
