saravanakumar.ms
.startData
Discussion created by saravanakumar.ms on Feb 28, 2013
what does the .startData contain other than the _startupData Structure. The Linker documentation says "A section for placing objects initialized by the Linker". I dont understand what these objects are. Could someone please provide an example ?
PS: In my S12XEP100 Project, the _startupData is 6 bytes big but the .startData section according to MAP file is 66 bytes. I could not trace out from the MAP file what the remaining 60 bytes contains.
Thanks a lot!
Saravanakumar
