I am using 32.768KHz crystal on XTALs for RTC application. I wonder Why this particular value?
Can anyone provide a reason for it plz?
Solved! Go to Solution.
That is the standar value for RTC's crystals. Just because if you divide 32.768 KHz by :
2,4,8,16,32,.....1024, 2048,...,32768 .you always get an integer value.
32.768 Khz/32768 = one exact second
Luis
Luis
