can't get kernel image error in imx25 pdk
Question asked by Arumugam Ramasamy on Feb 27, 2013
Branched to a new discussion
I am using iMX25 PDK with 3 stack configuration. I have reproduced the CPU boards and using with the personality board supplied by freescale. While booting from SD card, the original CPU is booting and one of my newly produced CPUs is also booting. But without changing the SD Card, if I change the CPU, it is not booting up. Saying that can't load kernel image. The log files of good and bad booting are attached. Need help to find the reason why is it malfunctioning between CPU to CPU.
Arumugam R
Original Attachment has been moved to: Kernel-Loaded.txt.zip
Original Attachment has been moved to: Can't-get-kernel-image.txt.zip
