Floating Point Library
Question asked by Dave Miller on Feb 27, 2013
Latest reply on Feb 28, 2013 by Dave Miller
Hello All,
OK, this should hopefully be a simple issue but I can't seem to find the answer.
I started a project with CW10.3 for the HCS08 CPU (S08AW60) and when I started the project wizard I did not select the floating point library.  Now I find myself wanting to use floating point for 1 calculation but I can't find the setting to use the correct floating point lib.
I am using the ADS1118 for thermocouple measurement and I need to calculate the internal temperature sensor value:
#include <float.h>
float Temp_Sensor;
int Sensor_Reading;
Temp_Sensor  = (float)Sensor_Reading * 0.03125;                                  //calculate degrees
When I compile this I get the following errors:
I am pretty certain the issue is the missing floating point library.
Can anyone tell me where I go to include the floating point libraries in my project?  I looked all through the project settings and don't see a "use floating point libraries" check box.
Dave
