ATK Tool compilation error
arumugamramasam
I am trying to compile the ATK tool source under ubuntu using the same tool chain which I am using for LTIB. When I run the make file as mentioned in the application note AN3985, I am facing an error as attached. The log file is attached for better undersatnding. Need help to resolve this compilation error.
Arumugam R
arumugam@arumugam-laptop:~/ATK_Tool/AdvancedToolKit1.71_Source_STD/device_program$ make clean
make -C ram_kernel/ clean
make[1]: Entering directory `/home/arumugam/ATK_Tool/AdvancedToolKit1.71_Source_STD/device_program/ram_kernel'
make[1]: Leaving directory `/home/arumugam/ATK_Tool/AdvancedToolKit1.71_Source_STD/device_program/ram_kernel'
make -C fuse/ clean
make[1]: Entering directory `/home/arumugam/ATK_Tool/AdvancedToolKit1.71_Source_STD/device_program/fuse'
make[1]: Leaving directory `/home/arumugam/ATK_Tool/AdvancedToolKit1.71_Source_STD/device_program/fuse'
make -C flash/ clean
make[1]: Entering directory `/home/arumugam/ATK_Tool/AdvancedToolKit1.71_Source_STD/device_program/flash'
make[1]: Leaving directory `/home/arumugam/ATK_Tool/AdvancedToolKit1.71_Source_STD/device_program/flash'
make -C init/ clean
make[1]: Entering directory `/home/arumugam/ATK_Tool/AdvancedToolKit1.71_Source_STD/device_program/init'
rm -rf *.o
make[1]: Leaving directory `/home/arumugam/ATK_Tool/AdvancedToolKit1.71_Source_STD/device_program/init'
rm -f bin/*.elf
rm -f bin/*.map
arumugam@arumugam-laptop:~/ATK_Tool/AdvancedToolKit1.71_Source_STD/device_program$ make MCU=mx25 FLASH_TYPE=nand
start building ...
[Building initial ...]
make -C init/
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -o init.o init.s
[Building RAM Kernel ...]
make -C ram_kernel/ all
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc -o src/platform/mx25/src/bl_transreceiver.o src/platform/mx25/src/bl_transreceiver.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'src/platform/mx25/src/bl_transreceiver.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc src/platform/mx25/src/bl_transreceiver.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc -o src/platform/mx25/src/channel.o src/platform/mx25/src/channel.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'src/platform/mx25/src/channel.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc src/platform/mx25/src/channel.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc -o src/platform/mx25/src/platform.o src/platform/mx25/src/platform.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'src/platform/mx25/src/platform.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc src/platform/mx25/src/platform.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc -o src/platform/mx25/src/serial_downloader.o src/platform/mx25/src/serial_downloader.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'src/platform/mx25/src/serial_downloader.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc src/platform/mx25/src/serial_downloader.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc -o src/platform/mx25/src/usb_hwinterface_layer.o src/platform/mx25/src/usb_hwinterface_layer.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'src/platform/mx25/src/usb_hwinterface_layer.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc src/platform/mx25/src/usb_hwinterface_layer.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc -o src/platform/mx25/src/usb_transaction_layer.o src/platform/mx25/src/usb_transaction_layer.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'src/platform/mx25/src/usb_transaction_layer.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc src/platform/mx25/src/usb_transaction_layer.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc -o src/main.o src/main.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'src/main.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DREV_ -Isrc/platform/mx25/inc/ -I../global_inc src/main.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ld  -r -o ramkernel.o  src/platform/mx25/src/bl_transreceiver.o  src/platform/mx25/src/channel.o  src/platform/mx25/src/platform.o  src/platform/mx25/src/serial_downloader.o  src/platform/mx25/src/usb_hwinterface_layer.o  src/platform/mx25/src/usb_transaction_layer.o src/main.o
[Building Flash Library ...]
make -C flash/ all
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DMCU_MX25 -DREV_ -Inand_flash/inc/  -I../global_inc -o nand_flash/src/flash_lib.o nand_flash/src/flash_lib.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'nand_flash/src/flash_lib.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DMCU_MX25 -DREV_ -Inand_flash/inc/  -I../global_inc nand_flash/src/flash_lib.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DMCU_MX25 -DREV_ -Inand_flash/inc/  -I../global_inc -o nand_flash/src/nand_bbt.o nand_flash/src/nand_bbt.c
nand_flash/src/nand_bbt.c: In function 'mark_bbt_region':
nand_flash/src/nand_bbt.c:760: warning: implicit declaration of function 'nand_update_bbt'
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'nand_flash/src/nand_bbt.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DMCU_MX25 -DREV_ -Inand_flash/inc/  -I../global_inc nand_flash/src/nand_bbt.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DMCU_MX25 -DREV_ -Inand_flash/inc/  -I../global_inc -o nand_flash/src/nand_device_info.o nand_flash/src/nand_device_info.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'nand_flash/src/nand_device_info.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DMCU_MX25 -DREV_ -Inand_flash/inc/  -I../global_inc nand_flash/src/nand_device_info.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DMCU_MX25 -DREV_ -Inand_flash/inc/  -I../global_inc -o nand_flash/src/nand_flash.o nand_flash/src/nand_flash.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'nand_flash/src/nand_flash.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DMCU_MX25 -DREV_ -Inand_flash/inc/  -I../global_inc nand_flash/src/nand_flash.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DMCU_MX25 -DREV_ -Inand_flash/inc/  -I../global_inc -o nand_flash/src/nfc_base.o nand_flash/src/nfc_base.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'nand_flash/src/nfc_base.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DMCU_MX25 -DREV_ -Inand_flash/inc/  -I../global_inc nand_flash/src/nfc_base.c >> .depend
Start
nand_flash
nand_flash
End
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ld  -r -o flashlib.o  nand_flash/src/flash_lib.o  nand_flash/src/nand_bbt.o  nand_flash/src/nand_device_info.o  nand_flash/src/nand_flash.o  nand_flash/src/nfc_base.o
[Building Fuse Library ...]
make -C fuse/ all
make[1]: *** No rule to make target `fuse_lib.o', needed by `all'.  Stop.
make: *** [all] Error 2
Original Attachment has been moved to: ATKTool_Compilation_log.zip
JasonLiu
Dear Arumugam Ramasamy:
Since you are using the STD source code package, you need add flashlib into the build command:
arumugam@arumugam-laptop:~/ATK_Tool/AdvancedToolKit1.71_Source_STD/device_program$ make MCU=mx25 flashlib FLASH_TYPE=nand
flashlib:
The option "flashlib" will build only the Flash library and the fuse library will be built out since the STD package not support fuse library.
Details, please read FSL_ATK_ReferenceManual_Std.pdf, which located into your source code package.
Jason  Liu
arumugamramasam
Hi Jason Liu,
Thanks for the information. I tried including flashlib as make command parameter, but this time it throws a different error. Please find the below log...
start building ...
make -C init/
make -C flash/ all
Start
nand_flash
nand_flash
End
make -C fuse/ all UNIT_TEST=y
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -c -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DTO1 -DMCU_MX25 -DREV_ -I./ -I../global_inc -o unit_test/fake_fuselib.o unit_test/fake_fuselib.c
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -MM -MT 'unit_test/fake_fuselib.o' -Wall -Wstrict-prototypes -Wno-trigraphs  -nostartfiles -O0  -nostdlib -static -feliminate-unused-debug-symbols -fno-strict-aliasing -fno-common -pipe -fno-builtin  -g -mapcs -mlittle-endian -msoft-float -mfpu=fpa -mcpu=arm926ej-s -DTO1 -DMCU_MX25 -DREV_ -I./ -I../global_inc unit_test/fake_fuselib.c >> .depend
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ld  -r -o fuselib.o unit_test/fake_fuselib.o
[Generate RAM Kernel image ...]
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc -nostartfiles -static -Wl,-Map,bin/mx25_nand.map -Tram_kernel_mx25.lds -o bin/mx25_nand.elf init/init.o ram_kernel/ramkernel.o fuse/fuselib.o flash/flashlib.o
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/lib/gcc/arm-none-linux-gnueabi/4.1.2/../../../../arm-none-linux-gnueabi/bin/ld: BFD 2.17 assertion fail /usr/src/redhat/BUILD/cross-mlib/source/binutils-2.17/bfd/elf.c:3878
/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/lib/gcc/arm-none-linux-gnueabi/4.1.2/libgcc_eh.a(unwind-arm.o): In function `get_eit_entry':
/usr/src/redhat/BUILD/cross-mlib/source/gcc-4.1.2/gcc/config/arm/unwind-arm.c:459: undefined reference to `__exidx_start'
/usr/src/redhat/BUILD/cross-mlib/source/gcc-4.1.2/gcc/config/arm/unwind-arm.c:459: undefined reference to `__exidx_end'
collect2: ld returned 1 exit status
make: *** [flashlib] Error 1
Arumugam R
JasonLiu
Please add the following into the end lds file: ram_kernel_mx25.lds
__exidx_start = .;
__exidx_end = .;
Jason Liu
erickang
Dear Hui Liu,
I have a question to build the ATK binary for i.MX25.
I'm using the ubuntu 11.04 to build the ATK.
For building ATK in ubuntu, I modified below 2 files.
1) rules.make
# in Cygwin
#CC = arm-elf-gcc
#AS = arm-elf-as
#LD = arm-elf-ld
#NM = arm-elf-nm
#OBJDUMP = arm-elf-objdump
#OBJCOPY = arm-elf-objcopy
#READELF = arm-elf-readelf
# in Linux // Eric
CC = /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc
AS = /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-as
LD = /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ld
NM = /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-nm
OBJDUMP = /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-objdump
OBJCOPY = /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-objcopy
READELF = /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-readelf
2) ram_kernel_mx25.lds
SECTIONS
__exidx_start = .;
__exidx_end = .;
And I just built the ATK image with below commands. I could confirm the created mx25_nand.bin in bin folder.
But the file was not operated in EVK using Samsung Nandflash, K9LBG08U0M-PCB0.
(This nandflash is included in the default ATK code.)
Could you give me any advice to build mx25_nand.bin of ATK?
Eric.
arumugamramasam
Hi Jason,
I have another issue in booting. Please let me know if you could interpret something from the logs attached, which will be helpful for me to solve the issue.
I am using iMX25 PDK with 3 stack configuration. I have reproduced the CPU boards and using with the personality board supplied by freescale. While booting from SD card, the original CPU is booting and one of my newly produced CPUs is also booting. But without changing the SD Card, if I change the CPU, it is not booting up. Saying that can't load kernel image. The log of bad booting is given below. Need help to find the reason why is it malfunctioning between CPU to CPU.
Arumugam R
U-Boot 2009.08 (Feb 18 2013 - 10:40:36)
CPU:   Freescale i.MX25 at 398 MHz
mx25 cpu clock: 398MHz
ipg clock     : 66498560Hz
Board: i.MX25 MAX PDK (3DS)
I2C:   ready
DRAM:  64 MB
NAND:  Unrecognized NAND Flash device.
256 MiB
MMC:   FSL_ESDHC: 0
UnCorrectable RS-ECC Error
*** Warning - bad CRC or NAND, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   smc911x-0 [PRIME], FEC0
Hit any key to stop autoboot:  0
MMC read: dev # 0, block # 2048, count 4096 ... 4096 blocks read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
STEPS U-Boot >
JasonLiu
Hi Arumugam R:
From the log:
256 MiB
MMC:   FSL_ESDHC: 0
Which means the NAND is not detected and thus you can't get the correct environment variables if the env is stored in the NAND.
And the following log:
I suspect that some default environment is correct, please check your bootcmd and see anything wrong. And also, please check whether the uImage in the SD card is correct or not.
arumugamramasam
Thanks jason.. I am able to produce new flash library..
Arumugam R
Yuri
Please try to use a toolchain, that generates non-Linux (stand-alone) application. In app note GNU ARM gcc is recommended.
