Gstreamer dual display resoultions
Question asked by William Tung on Feb 25, 2013
Latest reply on Feb 13, 2014 by Holger Moritz
Branched to a new discussion
We tried dual LVDS output and could play two video simultaneously on a solo board. However, the resolution of 2nd display always follows the first one. Is there anything we're missing?
u-boot parameter:
video=mxcfb0:dev=ldb,LDB-WVGA,if=RGB666 video=mxcfb1:dev=ldb,LDB-WSVGA,if=RGB666 ldb=sep0
check mode:
root@linaro-ubuntu-desktop:~# cat /sys/class/graphics/fb0/mode
D:800x480p-60
root@linaro-ubuntu-desktop:~# cat /sys/class/graphics/fb2/mode
D:1024x600p-60
video1:
gst-launch  filesrc location=/home/demo/albertsons.mp4 typefind=true  ! aiurdemux name=demux demux.  ! queue max-size-buffers=0 max-size-time=0 ! vpudec  ! mfw_v4lsink device=/dev/video16 demux. ! queue max-size-time=0  ! beepdec ! audioconvert ! 'audio/x-raw-int, channels=2' ! alsasink demux.
output:
MFW_GST_V4LSINK_PLUGIN 3.0.5 build on Dec 14 2012 13:58:00.
Setting pipeline to PAUSED ...
[INFO]  Product Info: i.MX6Q/D/S
vpudec versions
        plugin: 3.0.4
        wrapper: 1.0.25(VPUWRAPPER_ARM_LINUX Build on Dec  7 2012 20:22:02)
        vpulib: 5.4.8
        firmware: 2.1.8.34588
Pipeline is PREROLLING ...
Aiur: 3.0.4
Core: MPEG4PARSER_06.04.25  build on Nov  9 2012 10:33:54
  mime: video/quicktime; audio/x-m4a; application/x-3gp
  file: /usr/lib/imx-mm/parser/lib_mp4_parser_arm11_elinux.so.3.1
Content Info:
        URI:
              file:///home/demo/albertsons.mp4
        Idx File:
              /root/.aiur/.home.demo.albertsons.mp4.aidx
        Seekable  : Yes
        Size(byte): 36913315
Movie Info:
        Seekable  : Yes
        Live      : No
        Duration  : 0:01:36.595000000
        ReadMode  : File
        Track     : 2
Track 00 [video_000000] Enabled
        Duration: 0:01:36.595000000
        Language: und
        Mime:
              video/x-h264, parsed=(boolean)true, width=(int)1280, height=(int)720, framerate=
              (fraction)30000/1001, codec_data=(buffer)000000016764001fac248805005ba100000303e
              90000ea600f1832a00000000168ee3cb0
Track 01 [audio_000000] Enabled
        Language: und
        Mime:
              audio/mpeg, mpegversion=(int)4, channels=(int)2, rate=(int)44100, bitrate=(int)1
              46528, framed=(boolean)true, stream-format=(string)raw, codec_data=(buffer)1210
[INFO]  bitstreamMode 1, chromaInterleave 1, mapType 0, tiled2LinearEnable 0
[WARN]  VPU iram is less than needed, some parts don't use iram
>>V4L_SINK: Actually buffer status:
        hardware buffer : 9
        software buffer : 0
Beep: 3.0.4
Core: AAC-Plus decoder Wrapper  build on Nov  8 2012 16:49:52
  mime: audio/mpeg, mpegversion=(int){2,4}
  file: /usr/lib/imx-mm/audio-codec/wrap/lib_aacplusd_wrap_arm12_elinux.so.3
CODEC: BLN_MAD-MMCODECS_AACD_ARM_03.07.00  build on Jul 17 2012 17:47:46.
BLN_MAD-MMCODECS_AACPD_ARM_03.07.00_ARM11  build on Jul 17 2012 17:58:59.
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
full screen size:800x480
[V4L Update Display]: left=0, top=0, width=800, height=480
New clock: GstAudioSinkClock
video2:
gst-launch  filesrc location=/home/demo/albertsons.mp4 typefind=true  ! aiurdemux name=demux demux.  ! queue max-size-buffers=0 max-size-time=0 ! vpudec  ! mfw_v4lsink device=/dev/video18  demux.
output:
vpudec versions
        plugin: 3.0.4
        vpulib: 5.4.8
Aiur: 3.0.4
Content Info:
        URI:
        Idx File:
        Seekable  : Yes
Movie Info:
        Seekable  : Yes
        Live      : No
        ReadMode  : File
        Track     : 2
        Language: und
        Mime:
        Language: und
        Mime:
        hardware buffer : 9
        software buffer : 0
New clock: GstSystemClock
