Issues with SD Card & USB Interfaces on i.MX233
Question asked by GopiNagaBharath on Feb 25, 2013
Latest reply on Feb 27, 2013 by Nidal Prasovic
Branched to a new discussion
Hello Every one,
We want to be able to achieve the following through the imx233 EVK at one time:-
1)      Access the USB mass storage device
2)      Connect the EVK to the PC and access it as a mass storage device
3)      Access the SDCard
4)      Access the NAND Flash
We have made the following changes to the kernel.
For SPI Access
CONFIG _SPI = Y
CONFIG_SPI_MXS = [y | m]
FOR MMC Configuration
CONFIG_MMC
CONFIG_MMC_BLOCK
CONFIG_MMC_MXS
CONFIG_MMC_UNSAFE_RESUME
For USB Mass Storage and File Storage
CONFIG_USB
CONFIG_USB_EHCI_HCD
CONFIG_USB_EHCI_ARC
CONFIG_USB_EHCI_ARC_OTG
CONFIG_USB_EHCI_ROOT_HUB_TT
CONFIG_USB_STORAGE
CONFIG_USB_HID
CONFIG_USB_GADGET
CONFIG_USB_GADGET_ARC
CONFIG_USB_GADGET_ARC_OTG
ONFIG_USB_OTG
CONFIG_USB_FILE_STORAGE
After generating the kernel and rootfs with the above options the .sb images are burned to the nandflash and booted.
The command line give to boot is
initrd console=ttyAM0,115200 ssp1=spi1 ssp2=mmc ubi.mtd=1 root=ubi0:rootfs0 rootfstype=ubifs rw gpmi
Once the system boots I don’t see any
/dev/mmcblk# nodes in the rootfs
Once I insert the USB EHCI driver
insmod ehci-hcd
I don’t see any nodes like below when I connect the USB stick
/dev/sd#
Could you please help in with
a)      How to access SDCard when I am booting from NANDFlash
b)      How to access USB stick driver
Attached is the bootup log.
Gopi
Original Attachment has been moved to: dmesg.txt.zip
