Under CW6.3 an array automatically displayed as ascii if the type was char. Under the debugger for CW10.3 I can't find anyway to display anything as ascii. Is there a way to look at a string array as an ascii string? I have searched the posts but can't find anything, maybe my search terms are wrong.
Robert
Solved! Go to Solution.
Hi Erich
Brilliant...Part 2 was the answer. If I cast it to unsigned char * as you pointed out, it works as expected. I will try changing the type to unsigned char for the array in the code and see if I can avoid the extra step.
Thank you... this was driving me crazy looking up values in ascii charts!!
Robert
