about imx6d memory DMA test
Question asked by sandy zhao on Feb 21, 2013
Latest reply on Jul 3, 2014 by jimmychan
Branched to a new discussion
1.I reserve 20MB memory using  linux kernel cmdline "mem=800".
2.I want use sdma to copy the first 10MB to second 10Mb position ,and then to get the used time
3.I use imx-test-3.0.0\module_test\mxc_sdma_mem_test.c,but cant compile it
work_sandy_host/nfs_host/test_memory_dma/test_module/mxc_sdma_mem_test.c : In function 'mxc_printSDMAcontext':
/work_sandy_host/nfs_host/test_memory_dma/test_module/mxc_sdma_mem_test.c :52:2: error: implicit declaration of function 'IO_ADDRESS' [-Werror=implicit-function-declaration]
/work_sandy_host/nfs_host/test_memory_dma/test_module/mxc_sdma_mem_test.c :52:40: error: 'MX6Q_SDMA_BASE_ADDR' undeclared (first use in this function)
/work_sandy_host/nfs_host/test_memory_dma/test_module/mxc_sdma_mem_test.c :52:40: note: each undeclared identifier is reported only once for each function it appears in
/work_sandy_host/nfs_host/test_memory_dma/test_module/mxc_sdma_mem_test.c : In function 'sdma_open':
/work_sandy_host/nfs_host/test_memory_dma/test_module/mxc_sdma_mem_test.c :146:2: error: implicit declaration of function 'mxc_dma_request' [-Werror=implicit-function-declaration]
/work_sandy_host/nfs_host/test_memory_dma/test_module/mxc_sdma_mem_test.c :146:33: error: 'mMXC_DMA_MEMORY' undeclared (first use in this function)
make[1]: Leaving directory `/work_sandy_host/linux_imx6'
4.can you give me some advice?
