I would like to debug the kernel in the presence of Topaz hypervisor.
I enabled kernel debugging and I compiled the images. I followed "QorIQ debbuging user's guide" and exactly performed the steps for QorIQ debugging, in the presence of hypervisor. The QorIQ debug module does not get loaded. Does hypervisor intervene when I try to "modprobe qoriq-dbg" in the kernel?
Should I change hypervisor configuration and rebuild embedded-hv so that the hypervisor lets the kernel access the registers that I am interested in?
It would be really great if someone has already worked on something similar and can clear my doubts.
I am able to debug the kernel when the kernel is standalone without any partitions and hypervisor.
A Vasu
Hi Vasu,
Few comments below ...
There shouldn't be any interaction between hypervisor and the module.
The debug resources (registers and interrupt) are given to the guest by default so you shouldn't need to change the hypervisor config. Unless you use a very old hypervisor version that by default allocated the debug resources to the hypervisor or, by chance, you have a "guest-debug- disable" property in your partition definition node in the configuration.
Can you explore other options such as using gdb with the gdb-stub included in Topaz (see Embedded Hypervisor User's Manual, Apendix A for details)?
What version of hypervisor are you using?
Can you share the config file?
HTH, Laurentiu
Sorry about the late response. I do not have a "guest-debug-disable' property defined in the partition definition node. I am attaching the hypervisor and kernel configuration device trees.
Here are the versions of the hypervisor and kernel.
Hypervisor version:
Freescale Embedded Hypervisor version 1.2-003
Linux version:
Linux p4080ds 3.0.34-rt55-02404-g1a39570 #1 SMP PREEMPT RT Wed Feb 27 21:38:39 CST 2013 ppc GNU/Linux
Please let me know if I am going wrong somewhere.
A vasu
