Nichelite applications VS MQX and RTCS
diegoalonso
I starting developing an UDP aplication with the MFC52259EVB. I started with Codewarrior 7.3 and with the Nichelite TCP/ip stack.
Currently am trying to use codewarrior 10.3 and the RTCS library, but when a I create a symple example with MQX 4.0 the follow message appear
"Size of the application has exceeded the capability of this license. Contact your authorized distributor or Freescale to purchase a full version of the tools".
My question is: Can I use MQX 4.0 with the RTCS library with evaluation version of codewarrior 10.3????? Can I migrate easily, my codewarrior 7.3 proyect to codewarior 10.3??
There is some advantage using MQX with RTCS vs Nichelite???
doron2006
Hola Diego te contesto cada pregunta abajo:
La podés bajar de Freescale y lo podés usar por 30 días gratis. No te va a tirar mas el error "Size of the application has exceeded the capability of this license. Contact your authorized distributor or Freescale to purchase a full version of the tools" te paso el linik:
https://www.freescale.com/webapp/Download?colCode=CWX-MCU-LLPLT-EX&nodeId=015210272600612247&appType...
No tanto ya, que las librerías que trae de TCP/IP son usando RTCS de MQX
La ventaja mayor que veo es el soporte de freescale (ejemplos, notas de aplicación) al ser parte de MQX. CodeWarrior 10.3 permite debuguear mas facilmente la aplicación. Adicionalmente podés contar con comunicación segura https usando el cliente de Nano
https://community.freescale.com/thread/81148
Saludos   Diego
doron2006
Saludos   Diego
