Hi, I recently received IM6 Sabre Automotive Infotainment board, partitoned the SDcard using script "fsl-sdcard-partition.sh" and trying to boot factory images from SDcard, not successful getting u-boot prompt on serial console, the board comes with 8GB Sdcard loaded ubuntu OS, boots without issues, could someone suggest what could be going wrong with creating partitions using the script, I know this target board support SecureBoot using HAB concept, do I need to sign the u-boot using any tool before copying it to target board?
Subbu
Solved! Go to Solution.
It´s not related with secureboot, forget about it.
Something went wrong with your partition script, maybe your sdcard or maybe lacking of sudo.
So, my suggest is that you take User Guide and create the sdcard by your own.
I mean, start coping only the u-boot, than you try to boot (only with u-boot you must see some log).
