Hi, I have purchased a MVME167-01Bboard, but the factory default 167Bug firmware EPROMS have been removed.
Does anyone know where I may be able to acquire some replacemnts from or where I can download the ROM image so that I can burn my own EPROMS
many thanks in advance
Solved! Go to Solution.
OK - I have found a supplier of original 167BUG PROMS "Innovative Research" http://www.mvme.com/
Who can supply, which is good as my MVME167 board was limited without them.
They will be able to supply other MVME boards DEBUG PROMS I supect
