In CW 10.3, when you create a project there an I/O support: Debbuger Console.
I suspect this is what you need to use.
I have not tryed it.
Hello
FAQs have been removed from the system and should be integrated in the community portal some times in the future.
I checked internally and FAQ-28993 is specific to Coldfire MCU. It does not apply to Kinetis so it would not help in your case.
Try getting assistance from the CodeWarior for MCU community and if this does not work, you can submit a service request through our on line support web page.
CrasyCat
