problem with build obds project
Question asked by cao ping on Feb 3, 2013
Latest reply on Feb 5, 2013 by cao ping
Hi,everyone
now i want to have one test project on my computer to test the imx53 board,  i install the Ubuntu 10.04
according to "README_Ubuntu_VM.pdf",
when i run "cat /proc/version",it displays
Linux version 2.6.32-21-generic (buildd@rothera) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #32-Ubuntu SMP
Fri Apr 16 08:10:02 UTC 2010
and then i download "I201139_mx53_sbrth_lcb_release" on freescale webside,and
coye"I201139_mx53_sbrth_lcb_release" to ubuntu "Desktop",and change I201139_mx53_sbrth_lcb_release's name
into obds,in the path /Desktop/obds,when i run"make TARGET=mx53 BOARD=sbrth_lcb BOARD_VERSION=1",it displays
mkdir -p output
mkdir -p output/mx53
mkdir -p /home/lucid/Desktop/obds/output/mx53/lib
mkdir -p /home/lucid/Desktop/obds/output/mx53/bin
make -S -C src dir
make[1]: Entering directory `/home/lucid/Desktop/obds/src'
make -S -C drivers dir
make[2]: Entering directory `/home/lucid/Desktop/obds/src/drivers'
make -S -C usb dir
make[3]: Entering directory `/home/lucid/Desktop/obds/src/drivers/usb'
make -S -C imx_usb dir
make[4]: Entering directory `/home/lucid/Desktop/obds/src/drivers/usb/imx_usb'
arm-none-eabi-ar -rucs /home/lucid/Desktop/obds/output/mx53/lib/libobds.a
/home/lucid/Desktop/obds/output/mx53/obj/imx_usb/usb_h1.o
/home/lucid/Desktop/obds/output/mx53/obj/imx_usb/usb_test.o
make[4]: arm-none-eabi-ar: Command not found
make[4]: *** [all] Error 127
make[4]: Leaving directory `/home/lucid/Desktop/obds/src/drivers/usb/imx_usb'
make[3]: *** [imx_usb] Error 2
make[3]: Leaving directory `/home/lucid/Desktop/obds/src/drivers/usb'
make[2]: *** [usb] Error 2
make[2]: Leaving directory `/home/lucid/Desktop/obds/src/drivers'
make[1]: *** [drivers] Error 2
make[1]: Leaving directory `/home/lucid/Desktop/obds/src'
make: *** [src] Error 2
and when i change
CC= arm-none-eabi-gcc
AS = arm-none-eabi-as
AR = arm-none-eabi-ar
LN = arm-none-eabi-ld
into
CC = /opt/freescale/usr/local/gcc-4.4.4-glibc-2.11.1-multilib-1.0/arm-fsl-linux-gnueabi/bin/arm-fsl-linux-gnueabi-gcc
AS = /opt/freescale/usr/local/gcc-4.4.4-glibc-2.11.1-multilib-1.0/arm-fsl-linux-gnueabi/bin/arm-fsl-linux-gnueabi-as
AR = /opt/freescale/usr/local/gcc-4.4.4-glibc-2.11.1-multilib-1.0/arm-fsl-linux-gnueabi/bin/arm-fsl-linux-gnueabi-ar
LN = /opt/freescale/usr/local/gcc-4.4.4-glibc-2.11.1-multilib-1.0/arm-fsl-linux-gnueabi/bin/arm-fsl-linux-gnueabi-ld
and run "make TARGET=mx53 BOARD=sbrth_lcb BOARD_VERSION=1",it displays
/home/lucid/Desktop/obds/src/init/sys.c:137: warning: its scope is only this definition or declaration,
which is probably not what you want
/home/lucid/Desktop/obds/src/init/sys.c: In function '_write':
/home/lucid/Desktop/obds/src/init/sys.c:183: warning: null argument where non-null required (argument 2)
/home/lucid/Desktop/obds/src/init/sys.c:186: warning: null argument where non-null required (argument 2)
collect2: ld terminated with signal 11 [Segmentation fault]
/opt/freescale/usr/local/gcc-4.4.4-glibc-2.11.1-multilib-1.0/arm-fsl-linux-gnueabi/bin/../lib/gcc/arm-fsl-
linux-gnueabi/4.4.4/../../../../arm-fsl-linux-gnueabi/bin/ld: BFD (GNU Binutils) 2.20.1.20100303 assertion
fail /work/arm-toolchains/tmp/src/binutils-2.20.1/bfd/elf32-arm.c:12429
make: *** [bin] Error 1
how can i compile the project,can anyone use it?
