56F8357 ext. memory (EMI)
Question asked by Ben on Feb 2, 2013
Latest reply on Jul 25, 2013 by Ben
I am trying to connect the 56F8357 to external RAM via external 8 bit data bus.
I defined the bus to 8 bit, and I can communicate with the RAM. However, I don't know how to define the data so I will be able to write arrays
of 8 bits data (unsigned char). Trying to copy array from internal to external RAM copy only the odd array elements. I assume that it is because of the
data in the internal RAM stored in 16 bits array. Any idea how it can be done?
TIA
