ADD LDD on FRDM board causes PE ISR
Question asked by Steven Cohen on Feb 1, 2013
Latest reply on Feb 2, 2013 by Steven Cohen
vision4legacy2_1_13PE_ISR.zip is attached in my documents which should be visible.
When trying to utilize the ADC I get the PE ISR shown below.  Previously using the DAC LDD caused this by not
using auto initialization in the component properties, but that didn't solve the ADC problem.  Any help why this is happening?
PE_ISR(Cpu_Interrupt)
  /* This code can be changed using the CPU component property "Build Options / Unhandled int code" */
  PE_DEBUGHALT();
