I am using the Code Worry IDE, following an example of using processor expert.
On clicking the TSS_library , the following message appears:
Error: Cannot add component TSS_library to Device initialization project. Use "Target Processor" view to configure processor peripherals.
I would like to know what the target processor view is, and how it may be used.
Also, where it is, or how it may be invoked or otherwise made to appear.
this message is correct but seems is confusing. Anyway - TSS_Libray cannot be used in DI. In case you want to use it please create a project for ProcessorExpert.
For future question related to PEx please use corresponding forum: Processor Expert Software
best regards
Vojtech Filip
Processor Expert Support Team
