Hello everybody,
I'm starting to work with imx51, and I have a problem with the initialization of the USB Host
working with IC-USB transceiver.
If any of you do something like that?
Thank you
Lukas
Solved! Go to Solution.
Becaseu the usb phy interface follow the usb standard,
just use the official bsp kernel code, it initialized ok.
I've use 2 kinds of phy, both are ok.
