We have a new design based on i.MX6 solo.
I wanted to validate the pin settings using the windows IOMUX tool (using version 3.2.1).
We have pin EIM_LBA that is set to be BOOT_CFG[26]
So I go to the WEIM section in the "signal selection pane" (leftmost pane). Next I select WEIM_LBA. I can see that by default, it is set to ALT0-EIM_LBA(K22). But I CAN'T change it to src_BT_CFG[26] ALT7 (when i hover my mouse on WEIM_LBA I can see the choices ...but I can't change it).
Any ideas?
-jf simon
Solved! Go to Solution.
The latest version on the web now is version 3.4. please try the new version.
