imx53qsb usb device not working and how to enable the device mode in mx535qsb board.
Question asked by Venkatesh P on Jan 24, 2013
Latest reply on Jan 29, 2013 by Venkatesh P
Branched to a new discussion
hi,
   I was tested usb device in mx53 board and not working device mode.
My Menuconfig settings are here below.
First one i was set for following   menuconfig settings:
        "CONFIG_MXC_OTG, CONFIG_USB_OTG\n
        "CONFIG_USB_EHCI_ARC_OTG\n"
        "OTG device config\n"
        "CONFIG_USB_GADGET\n"
  I got in serial port/console message while i was insert and remove in USB device cable(J3).
usb wakeup is here
otg host ID wakeup
hub 1-0:1.0: activate --> -22
usb wakeup is here
otg host ID wakeup
also usb driver not installed in this settings
second  one i was set USB device mode  settings and udb driver not installed .
in device mode was not working and if any settings are missing compare to above device mode configuration please  tell me the correct procedure to enable imx53qsb device mode .
