I am trying remote debug a program running on the Sabre with eclipse. I have no problem using 'ddd' but when using eclipse, the program does not stop in the break points I set - it just runs through to the end.
The only output I get int eclipse's console is the following output:
warning: Unable to find dynamic linker breakpoint function.
GDB will be unable to debug shared library initializers
and track explicitly
David
David
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
David
We have not got your response yet and will close the diacussion in 3 days. If you still need help, please feel free to
reply with an update to this discussion.
Yixing
David
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the
issue, can we close the discussion? If you still need Freescale help, please feel free to contact us.
Yixing
