Parsing Error Can't open "MK60D10.mem" file
Question asked by Girish Choudankar on Jan 18, 2013
Latest reply on Jan 21, 2013 by Girish Choudankar
Hi-
I am using TWR K60D100M tower system with CW10.2 (Special Edition) and MQX3.8.1. I am using OSBDM for debugging purpose. The driver seems to installed correctly with current update. It get detected as COM3 on serial port. I have settings for Built Configurations as Int Flash Debug. Then I continue with Build Project (I tired Build All also) and which runs smoothly without any error. Under the Debug Configuration I have following settings:
Build Configuration: Int Flash Debug
Use Work Space settings checked
Application: intflash_d.afx
When I hit Debug, I get following error:
Failed to resume target process., There was an error parsing the memory configuration file:
("twrk60d100m.mem":20)
I am not sure why this error is coming or am I missing any settings? If this is not right forum then could anyone direct me to right place.
