Is it possible to change the MQX 4.0 root directory or install it to a different place?
This is a configuration management thing, no biggie if it can’t be done. MQX Rocks---
Cheers,
Tom
Solved! Go to Solution.
Thanks Kojto,
I needed to do an uninstall and install, that did it :smileycool:
Cheers
Hello Tom Junkans,
yes, it allows you to install it to specific directory.
MartinK
Thanks Kojto,
Cheers
