Extended Linear address Generation in Hex record
murugan_m
I generated a hex record file in code warrior by check the Generate X record check box. The generated hex file does not have a extended linear address at the required location (i e) it does not have a extended linear address record when the upper 16 bit addresses changes it have the extended linear address record after some records(lines).
what is the reason for this?? please ASAP
I attached the file with required comments. Please go through
Original Attachment has been moved to: Hex-file.hex.zip
Tags (2)
murugan_m
The issue get resolved. there is a issue in code warrior 10.2, now 10.4 is fine. sorry for late update
trytohelp
Dear Murugan,
We apologize for this problem.
We introduced a new process for community to avoid long un-answer question.
Thanks a lot for the information.
regards
Pascal
