When building the MQX 4.0 libraries for the TWRK60N512 using CW 10.2, I get the following warning message:
Mismatch between the condition and the previous IT instruction dispatch.S /psp_twrk60n512/PSP Cortex line 849 C/C++ Problem
Does anyone know if this is a problem?
I have attached the source code.
Joe.
Original Attachment has been moved to: dispatch.S.zip
Solved! Go to Solution.
Hello Joe Vignola,
it's caused by workaround for CW 10.2 (I believe also for 10.1) because of non-existing store/load exclusive instructions there. By the way, CW10.3 compiler seems to contain those instructions and the conditional directive can be removed there.
MartinK
Hello Joe Vignola,
MartinK
