while using Ethernet SDcard cannot be used
Question asked by Swapnil Katre on Jan 2, 2013
Latest reply on Jan 11, 2013 by Swapnil Katre
i am working on a product using K60 controller + twr. i have used the RTCS and MFS library in development, as different module my code for MFS (data logging on SDcard) and Server/client codes are working fine.
when i downloaded only server/client code which is working fine. but when i insert the sdcard in the slot at the same moment the activity LED on Ethernet Socket goes OFF and connection is disconnected. and if i remove the Card from the slot the LED start glowing with resuming the connection.
now i am not able to understand why this is happening as when i checked the schematic of the tower board, i see no relation in the pins for sdcard and Ethernet.
Please help me i anyone now where to find the solution for the same.
Swapnil
