If I understand the i.mx233 datasheet correctly, the default JTAG mode is the freescale proprietary serial JTAG. To use the Parallel JTAG I need to burn some bits in the OTP. My design doesn't expose the USB port, so I can't burn the bits that way. If PJTAG isn't available by default, how am I suppose to get PJTAG to work?
Solved! Go to Solution.
Grab this 30 euro device (olimex mx233 sjtag adapter) ... iMX233-SJTAG Olimex Ltd. | Mouser ... it should do the job.
