We are using Micron MT29F2G08ABAEAWP Nand flash in place of the original Samsung K9LAG08U0M-PCB0. When I tried with ATK tool V1.71 to load the Uboot, uImage, rootfs.jffs2 files on to the new flash with 3 stack configuration of PDK, I am facing error when I try to erase the flash. The error message is attached. I don't know, is there any specific procedure / setting to be maintained for changing the flash. Kindly help me resolving this issue and loading the images to the new flash.
Arumugam R
You need to add support for Your Flash in ATK. To do that you have to request the source code from freescale, and to change the NAND driver (device_program/flash/nand_flash) by adding the new Chip in nand_device_info.c.
Martin
Try Customer Support.
Martin
