It's my first time to use USBDM with a USB3.0 interface.
I found that the computer can recognize the USBDM,but the CodeWarrior IDE can't recognize it.
Solved! Go to Solution.
Dear pgo,
Thank you for your help.
Last time I used the USBDM V4.9.4 , It can not support USB3.
After I update the firmware, this problem has been solved . It's OK and work well.
Thanks for your hard work.
Dear he wei,
I have no USB3 devices to check USBDM with so I can't really offer concrete advice.
USBDM uses libusbx to access the usb devices. There is a support note for USB3 on this page that may be relevant. Could you check if this applies to your system?
Windows Backend · libusbx/libusbx Wiki · GitHub
Could you check operation with the standalone programmers as a further check?
I'll see if I can find a machine with a USB3 port to do some testing.
Also - what version of USBDM are you using?
bye.
Dear pgo,
