I'm trying to get the USB_FS-Module running in Device-Mode on the TWR-K60F120M System.
During initialisation I activate the USB-Reset Interrupt, the global USB-Interrupt in the NVIC and assign an ISR.
Then I apply a reset to the USB-Module by setting the USBRESET-Bit in the USBTRC0-Register.
But I don't get any Interrupt neither after powering up the tower nor after applying an USB-Connector to the TWR-SER-Module.
What do I do wrong?
Thanks for help,
Georg
Solved! Go to Solution.
I have found my mistake.
I didn't use the proper clock settings in the SIM.
Nevertheless, thanks for reading!
Georg
Georg
Sorry for the late reply, Georg, but it's great that you found and corrected the flaw...keep it going! :smileywink:
We'll be around!
Regards.
