Can I show the camera preview and one video playback on one screen?
Question asked by Li Jian on Dec 16, 2012
Latest reply on May 9, 2013 by ff
On the android platform, when I write one activity that show the camera preview and video playback on one screen, I got some errors:
10-19 09:44:48.179 I/FslOverlay(14861): Mixer thread refill the origin area to black
10-19 09:44:48.219 I/ipulib  (14861): external/linux-lib/ipu/mxc_ipu_hl_lib.c:956 ipu is busy
10-19 09:44:48.219 I/ipulib  (14861): external/linux-lib/ipu/mxc_ipu_hl_lib.c:958  for hope task mode 0x4!
10-19 09:44:48.219 E/FslOverlay(14861): Error!Obj0 mxc_ipu_lib_task_init failed mIPURet -1!
The fully log looks like the following:
10-19 09:44:46.179 I/ActivityManager(14861): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10000000 cmp=com.ceict.videoclientdemo/.VideoChat } from pid 15407
10-19 09:44:46.189 I/SurfaceFlinger(14861): mHw->getFormat() 4
10-19 09:44:46.219 D/AndroidRuntime(15407): Shutting down VM
10-19 09:44:46.219 I/ActivityManager(14861): Start proc com.ceict.videoclientdemo for activity com.ceict.videoclientdemo/.VideoChat: pid=15422 uid=10049 gids={1006, 3003, 1015}
10-19 09:44:46.229 D/dalvikvm(15407): GC_CONCURRENT freed 102K, 69% free 320K/1024K, external 0K/0K, paused 1ms+0ms
10-19 09:44:46.229 D/jdwp    (15407): Got wake-up signal, bailing out of select
10-19 09:44:46.229 D/dalvikvm(15407): Debugger has detached; object registry had 1 entries
10-19 09:44:46.289 I/WindowManager(14861): Setting rotation to 1, animFlags=1
10-19 09:44:46.309 I/ActivityManager(14861): Config changed: { scale=1.0 imsi=0/0 loc=zh_CN touch=3 keys=1/1/2 nav=1/1 orien=2 layout=268435490 uiMode=17 seq=3}
10-19 09:44:46.339 W/com.skype.rover.MainApp(15144): onConfigurationChanged changed:{ scale=1.0 imsi=0/0 loc=zh_CN touch=3 keys=1/1/2 nav=1/1 orien=2 layout=268435490 uiMode=17 seq=3}
10-19 09:44:46.359 V/KeyEvent(14953): Reset: android.view.KeyEvent$DispatcherState@2aff1d20
10-19 09:44:46.619 I/System.out(15422): CameraPreview
10-19 09:44:46.619 I/System.out(15422): Player
10-19 09:44:46.689 I/ActivityManager(14861): Displayed com.ceict.videoclientdemo/.VideoChat: +470ms
10-19 09:44:46.769 I/OMXPlayer(14850): Loading content: /mnt/sdcard/pic/camerarecorder.mp4
10-19 09:44:46.779 I/FslCameraHAL(14850): Face Back Camera is ov564, orient is 90
10-19 09:44:46.779 I/FslCameraHAL(14850): Face Front Camera is saf7113, orient is 270
10-19 09:44:46.779 I/FslCameraHAL(14850): It is the CSI device
10-19 09:44:46.779 I/FslCameraHAL(14850): V4l2CsiDevice: input=1
10-19 09:44:46.779 I/FslCameraHAL(14850): Create the software encoder
10-19 09:44:46.779 I/FslCameraHAL(14850): v4l2 input is 0x1
10-19 09:44:46.959 D/dalvikvm(14953): GC_EXTERNAL_ALLOC freed 193K, 49% free 2998K/5831K, external 4444K/4448K, paused 50ms
10-19 09:44:47.129 I/OMXPlayer(14850): mSurface changed: left: 165, right: 480, top: 0, bottom: 420, rot: 4
10-19 09:44:47.129 I/OMXPlayer(14850): Rotate to 4
10-19 09:44:47.139 D/szipinf (15324): Initializing inflate state
10-19 09:44:47.539 I/FslCameraHAL(14850): device name is /dev/video0
10-19 09:44:47.539 I/FslCameraHAL(14850): sensor name is ov5642_camera
10-19 09:44:47.539 I/FslCameraHAL(14850): mPreviewFormat :NV12
10-19 09:44:47.539 I/FslCameraHAL(14850): mUvcSpecialCaptureFormat :YUYV
10-19 09:44:47.539 I/FslCameraHAL(14850): mPreviewCapturedFormat :NV12
10-19 09:44:47.539 I/FslCameraHAL(14850): mPreviewCapturedFormat is 3231564e
10-19 09:44:47.539 I/FslCameraHAL(14850): the size is 640x480 , the framerate is 30
10-19 09:44:47.539 I/FslCameraHAL(14850): the size is 320x240 , the framerate is 30
10-19 09:44:47.539 I/FslCameraHAL(14850): the size is 720x480 , the framerate is 30
10-19 09:44:47.539 I/FslCameraHAL(14850): the size is 720x576 , the framerate is 30
10-19 09:44:47.539 I/FslCameraHAL(14850): the size is 1280x720 , the framerate is 30
10-19 09:44:47.539 I/FslCameraHAL(14850): the size is 1920x1080 , the framerate is 15
10-19 09:44:47.539 I/FslCameraHAL(14850): the size is 2592x1944 , the framerate is 15
10-19 09:44:47.539 I/FslCameraHAL(14850): ##The supportedPictureSizes is 640x480,320x240,720x480,720x576,1280x720,1920x1080,2592x1944##
10-19 09:44:47.539 I/FslCameraHAL(14850): ##the supportedPreviewSizes is 640x480,320x240,720x480,720x576,1280x720##
10-19 09:44:47.539 I/FslCameraHAL(14850): ##the supportedFPS is 15,30##
10-19 09:44:47.539 I/FslCameraHAL(14850): created the fsl Camera hal
10-19 09:44:47.539 I/FslCameraHAL(14850): ###the mesg enabled is d###
10-19 09:44:47.539 I/FslCameraHAL(14850): Trying to set overlay, but overlay is null!
10-19 09:44:47.539 I/FslOverlay(14861): overlay_createOverlay w 640,h 480,format 18, pid 14861,,gettid() 14868
10-19 09:44:47.539 I/FslOverlay(14861): num_buffer 3 width 640,height 480,format 18,buf_size 460800
10-19 09:44:47.539 I/FslOverlay(14861): V4L setting: format 0x59565955
10-19 09:44:47.549 I/FslOverlay(14861): v4l buf[0] 0x0xede20: vir 0x0x35ac8000,phy 0x95100000, size 770048
10-19 09:44:47.559 I/FslOverlay(14861): v4l buf[1] 0x0xede64: vir 0x0x35b84000,phy 0x94300000, size 770048
10-19 09:44:47.559 I/FslOverlay(14861): v4l buf[2] 0x0xedea8: vir 0x0x35c40000,phy 0x95300000, size 770048
10-19 09:44:47.559 I/FslOverlay(14861): Create overlay instance 0x0x2efdd0 id 0 total 1
10-19 09:44:47.559 I/FslOverlay(14861): overlay_setParameter param 3 value 1
10-19 09:44:47.559 I/FslOverlay(14861): getHandleRef return overlay_handle_t 0x0x2efe10
10-19 09:44:47.559 I/FslOverlay(14861): Overlay pos set: x 317,y 509,w 149,h 201
10-19 09:44:47.559 I/FslOverlay(14861): overlay_setParameter param 4 value 4
10-19 09:44:47.559 I/FslOverlay(14861): overlay_setParameter OVERLAY_TRANSFORM 4
10-19 09:44:47.559 I/FslOverlay(14861): overlay_setParameter param 5 value 21010
10-19 09:44:47.559 I/FslOverlay(14861): overlay_setParameter OVERLAY_ZORDER 21010
10-19 09:44:47.569 I/FslOverlay(14850): overlay_device_open data pid 14850,tid 14859
10-19 09:44:47.569 I/FslOverlay(14850): overlay_initialize overlay_handle 0x0x2c6b8 overlay_data_context_t 0x0x2c728 pid 14850 tid 14859
10-19 09:44:47.569 I/FslOverlay(14850): num_buffer 3 width 640,height 480,format 18, buf_size 460800
10-19 09:44:47.569 I/FslOverlay(14850): Info!get pmem total size 33554432
10-19 09:44:47.579 I/FslOverlay(14850): Allocator total size 1388544, vir addr 0x2c5df000, phy addr 0xae200000
10-19 09:44:47.579 I/FslOverlay(14850): overlay_buffer 0x0x2c830
10-19 09:44:47.579 I/FslOverlay(14850): buffer 0: vir 0x0x2c5df000, phy 0xae200000
10-19 09:44:47.579 I/FslOverlay(14850): buffer 1: vir 0x0x2c650000, phy 0xae271000
10-19 09:44:47.579 I/FslOverlay(14850): buffer 2: vir 0x0x2c6c1000, phy 0xae2e2000
10-19 09:44:47.579 I/FslOverlay(14850): Overlay init success for Id 0
10-19 09:44:47.579 I/FslCameraHAL(14850): Get the overlay to display
10-19 09:44:47.579 I/FslOverlay(14850): Id 0:overlay_data_setParameter push mode 1
10-19 09:44:47.579 I/FslCameraHAL(14850): ###start the capture the fps is 30000###
10-19 09:44:47.579 I/FslCameraHAL(14850): The capture device already open
10-19 09:44:47.599 I/FslCameraHAL(14850): the mode is 0
10-19 09:44:48.099 V/KeyEvent(15422): Reset: android.view.KeyEvent$DispatcherState@2afcf7e0
10-19 09:44:48.109 W/IInputConnectionWrapper(14953): showStatusIcon on inactive InputConnection
10-19 09:44:48.119 I/FslOverlay(14861): Overlay pos set: x 317,y 509,w 149,h 201
10-19 09:44:48.119 I/FslOverlay(14861): overlay_setParameter param 4 value 4
10-19 09:44:48.119 I/FslOverlay(14861): overlay_setParameter OVERLAY_TRANSFORM 4
10-19 09:44:48.119 I/FslOverlay(14861): overlay_setParameter param 5 value 21010
10-19 09:44:48.119 I/FslOverlay(14861): overlay_setParameter OVERLAY_ZORDER 21010
10-19 09:44:48.159 I/OMXPlayer(14850): start player.
10-19 09:44:48.159 I/OMXPlayer(14850): IpulibRender sInParam width 320, height 240,crop x 0, y 0, w 320, h 240, color 842094158
10-19 09:44:48.159 I/OMXPlayer(14850): IpulibRender sOutParam width 315, height 420,crop x 165, y 0, rot: 4, color 1498831189
10-19 09:44:48.299 I/FslOverlay(14861): V4L STREAMON NOW
10-19 09:44:48.299 I/ipulib  (14861): external/linux-lib/ipu/mxc_ipu_hl_lib.c:956 ipu is busy
10-19 09:44:48.299 I/ipulib  (14861): external/linux-lib/ipu/mxc_ipu_hl_lib.c:958  for hope task mode 0x4!
10-19 09:44:48.299 E/FslOverlay(14861): Error!Obj0 mxc_ipu_lib_task_init failed mIPURet -1!
10-19 09:44:48.329 I/ipulib  (14861): external/linux-lib/ipu/mxc_ipu_hl_lib.c:956 ipu is busy
10-19 09:44:48.329 I/ipulib  (14861): external/linux-lib/ipu/mxc_ipu_hl_lib.c:958  for hope task mode 0x4!
10-19 09:44:48.329 E/FslOverlay(14861): Error!Obj0 mxc_ipu_lib_task_init failed mIPURet -1!
10-19 09:44:48.369 I/ipulib  (14861): external/linux-lib/ipu/mxc_ipu_hl_lib.c:956 ipu is busy
10-19 09:44:48.369 I/ipulib  (14861): external/linux-lib/ipu/mxc_ipu_hl_lib.c:958  for hope task mode 0x4!
10-19 09:44:48.369 E/FslOverlay(14861): Error!Obj0 mxc_ipu_lib_task_init failed mIPURet -1!
