I was trying to run SABRE i.MX6Q BSP and Android framework on Android emulator.
(SABRE Board for Smart Devices Based on the i.MX 6 Series Product Summary Page)
It has succeeded to compile all of the source codes, BSP and Android framework.
Then I've copied zImage as kernel.img, ramdisk.img, userdata.img and system.img.
And launched it by the following command on Ubuntu linux.
$ emulator -kernel $ANDROID_IMG/kernel.img -ramdisk $ANDROID_IMG/ramdisk.img -sysdir $ANDROID_IMG -data $ANDROID_IMG/userdata.img -show-kernel -debug-init -verbose
Emulator window appeared but it was blacked out forever.
Is it possible to launch SABRE i.MX6Q BSP and their Android framework on Android emulator?
If possible, is there tips for it? Or is there an alternative way to do emulation?
Thank you,
Kengo Onoyama
I have never tested it myself, but I think it would work (I´m not sure regarding 3D/2D acceleration, but it would be a second step anyway).
When I worked with android emulator, one step for the procedure was create the rootfs image, and change the init.rc in order to load the emulator. Did you make any change?
Are you able to see the log? Please, share.
No response from customer. Assumed this was answered.
