Cannot install FSL_USB_Stack component in CW 10.3 project.
Question asked by injunear on Dec 12, 2012
Latest reply on Dec 12, 2012 by Erich Styger
Greetings all,
I am unable to successfully load FSL_USB_Stack in any project in CW 10.3. When I double click the component in the library, it shows up in my project for several seconds. It tries to set itself up then quits with "Error during adding component FSL_USB_Stack".
I am able to load other USB related components into my project and modify them in Component Inspector. I have downloaded the file from the website several times but am thoroughly unable to decipher where to even look for the cause of this problem.
Suggestions are gratefully invited.
Thank you.
