LTIB Build Error - imx-lib
Question asked by abdulrazak on Dec 4, 2012
Latest reply on Feb 1, 2013 by brunoceldran
Branched to a new discussion
Hi All,
I am running in to a issue while building ltib for i.mx35. Please help me solve this issue.
Also has some one built gstreamer package for i.mx35. If yes, please let me know the steps.
Below is the log.
Processing: imx-lib
Build path taken because: directory build, build key set, no prebuilt rpm,
rpmbuild --dbpath /home/dt-blr-04440/ltib/rootfs//var/lib/rpm --target arm --define '_unpackaged_files_terminate_build 0' --define '_target_cpu arm' --define '__strip strip' --define '_topdir /home/dt-blr-04440/ltib/rpm' --define '_prefix /usr' --define '_tmppath /home/dt-blr-04440/ltib/tmp' --define '_rpmdir /home/dt-blr-04440/ltib/rpm/RPMS'  --define '_mandir /usr/share/man' --define '_sysconfdir /etc' --define '_localstatedir /var' -bi --short-circuit  /home/dt-blr-04440/ltib/dist/lfs-5.1/mxc-misc/imx-lib.spec
Building target platforms: arm
Building for target arm
Executing(%install): /bin/sh -e /home/dt-blr-04440/ltib/tmp/rpm-tmp.17553
+ umask 022
+ cd /home/dt-blr-04440/ltib/rpm/BUILD
+ cd imx-lib-10.04.01
+ [ -z  ]
+ KERNELDIR=/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/../linux
+ KBUILD_OUTPUT=/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/../linux
+ rm -rf /home/dt-blr-04440/ltib/tmp/imx-lib
+ [ -n  ]
+ echo imx35_3stack
+ awk {print toupper($0)}
+ PLATFORM_UPPER=IMX35_3STACK
+ make PLATFORM=IMX35_3STACK DEST_DIR=/home/dt-blr-04440/ltib/tmp/imx-lib//opt/freescale/rootfs/arm install
make -C ipu install
make -C screenlayer install
make[1]: Entering directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/ipu'
make -C sim install
Not support platform, will not complile
make[1]: Leaving directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/ipu'
make -C vpu install
make[1]: Entering directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/screenlayer'
make[1]: Entering directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/sim'
make[1]: Nothing to be done for `install'.
make[1]: Leaving directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/sim'
make[1]: Leaving directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/screenlayer'
make[1]: Entering directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/vpu'
make[1]: Leaving directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/vpu'
+ exit 0
Processing files: imx-lib-10.04.01-1
error: File not found by glob: /home/dt-blr-04440/ltib/tmp/imx-lib/opt/freescale/rootfs/arm/*
RPM build errors:
Build time for imx-lib: 0 seconds
Failed building imx-lib
f_buildrpms() returned an error, exiting
traceback:
main:560
Started: Wed Dec  5 09:20:10 2012
Ended:   Wed Dec  5 09:26:32 2012
Elapsed: 382 seconds
These packages failed to build:
imx-lib
Build Failed
