How to patch r13.4-ga to Android 4.0.4
marcolin
Hello:
    I will developer Android with Sbarelite 6x board .The first ,I'll compiler Android source code with it. when I doing the section 5.1 "Patch Code for i.MX",
with the "c_patch /opt/imx-android-r13.4-ga/code/r13.4-ga imx_r13.4-ga" command,there are many error!How can I do?The error following:
Verify patches ...
Verify patch for build
error: patch failed: core/Makefile:784
error: core/Makefile: patch does not apply
error: patch failed: core/main.mk:756
error: core/main.mk: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/build.git to /home/linmao/imx6/myandroid/codeaurora/build. Stop
Verify patch for bionic
error: patch failed: libc/kernel/common/linux/ion.h:265
error: libc/kernel/common/linux/ion.h: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/bionic.git to /home/linmao/imx6/myandroid/codeaurora/bionic. Stop
Verify patch for bootable/recovery
error: patch failed: default_recovery_ui.c:38
error: default_recovery_ui.c: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/bootable/recovery.git to /home/linmao/imx6/myandroid/codeaurora/bootable/recovery. Stop
Verify patch for external/alsa-lib
warning: Android.mk has type 100644, expected 100755
Verify patch for external/alsa-utils
Verify patch for external/bluetooth/bluez
error: patch failed: tools/hciattach.c:1306
error: tools/hciattach.c: patch does not apply
error: patch failed: tools/hciattach.h:53
error: tools/hciattach.h: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/external/bluetooth/bluez.git to /home/linmao/imx6/myandroid/codeaurora/external/bluetooth/bluez. Stop
Verify patch for external/chromium
Verify patch for external/fsck_msdos
Verify patch for external/ppp
error: android/Android.mk: ?????????
error: patch failed: pppd/Android.mk:36
error: pppd/Android.mk: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/external/ppp.git to /home/linmao/imx6/myandroid/codeaurora/external/ppp. Stop
Verify patch for external/svox
Verify patch for external/tinyalsa
error: patch failed: include/tinyalsa/asoundlib.h:154
error: include/tinyalsa/asoundlib.h: patch does not apply
error: patch failed: pcm.c:794
error: pcm.c: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/external/tinyalsa.git to /home/linmao/imx6/myandroid/codeaurora/external/tinyalsa. Stop
Verify patch for external/webkit
warning: Source/WebCore/platform/graphics/ImageBuffer.h has type 100644, expected 100755
error: patch failed: Source/WebCore/platform/graphics/ImageBuffer.h:79
error: Source/WebCore/platform/graphics/ImageBuffer.h: patch does not apply
warning: Source/WebCore/platform/graphics/android/ImageBufferAndroid.cpp has type 100644, expected 100755
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/external/webkit.git to /home/linmao/imx6/myandroid/codeaurora/external/webkit. Stop
Verify patch for external/wpa_supplicant_8
error: patch failed: src/drivers/driver.h:704
error: src/drivers/driver.h: patch does not apply
error: patch failed: wpa_supplicant/.config:397
error: wpa_supplicant/.config: patch does not apply
error: patch failed: wpa_supplicant/Android.mk:1442
error: wpa_supplicant/Android.mk: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/external/wpa_supplicant_8.git to /home/linmao/imx6/myandroid/codeaurora/external/wpa_supplicant_8. Stop
Verify patch for frameworks/base
error: patch failed: core/jni/android_os_Power.cpp:59
error: core/jni/android_os_Power.cpp: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/frameworks/base.git to /home/linmao/imx6/myandroid/codeaurora/frameworks/base. Stop
Verify patch for frameworks/media/libvideoeditor
Verify patch for hardware/alsa_sound
warning: AudioStreamInALSA.cpp has type 100644, expected 100755
warning: AudioHardwareALSA.cpp has type 100644, expected 100755
error: patch failed: Android.mk:38
error: Android.mk: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/hardware/alsa_sound.git to /home/linmao/imx6/myandroid/codeaurora/hardware/alsa_sound. Stop
Verify patch for hardware/libhardware
error: modules/sensors/Android.mk: ?????????
error: modules/sensors/sensor.c: ?????????
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/hardware/libhardware.git to /home/linmao/imx6/myandroid/codeaurora/hardware/libhardware. Stop
Verify patch for hardware/libhardware_legacy
error: patch failed: wifi/Android.mk:28
error: wifi/Android.mk: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/hardware/libhardware_legacy.git to /home/linmao/imx6/myandroid/codeaurora/hardware/libhardware_legacy. Stop
Verify patch for hardware/ril
error: patch failed: reference-ril/reference-ril.c:43
error: reference-ril/reference-ril.c: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/hardware/ril.git to /home/linmao/imx6/myandroid/codeaurora/hardware/ril. Stop
Verify patch for libcore
Verify patch for packages/apps/Browser
Verify patch for packages/apps/Camera
error: patch failed: src/com/android/camera/panorama/PanoramaActivity.java:443
error: src/com/android/camera/panorama/PanoramaActivity.java: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/packages/apps/Camera.git to /home/linmao/imx6/myandroid/codeaurora/packages/apps/Camera. Stop
Verify patch for packages/apps/Gallery
Verify patch for packages/apps/Gallery2
error: patch failed: AndroidManifest.xml:59
error: AndroidManifest.xml: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/packages/apps/Gallery2.git to /home/linmao/imx6/myandroid/codeaurora/packages/apps/Gallery2. Stop
Verify patch for packages/apps/Launcher2
Verify patch for packages/apps/Music
Verify patch for packages/apps/Settings
error: src/com/android/settings/PluggableDisplaySettings.java: ?????????
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/packages/apps/Settings.git to /home/linmao/imx6/myandroid/codeaurora/packages/apps/Settings. Stop
Verify patch for packages/apps/SoundRecorder
Verify patch for packages/apps/VideoEditor
Verify patch for packages/inputmethods/PinyinIME
Verify patch for packages/providers/MediaProvider
Verify patch for packages/wallpapers/Basic
Verify patch for packages/wallpapers/MagicSmoke
Verify patch for prebuilt
Verify patch for system/core
error: ts_calibrator/Android.mk: ?????????
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/system/core.git to /home/linmao/imx6/myandroid/codeaurora/system/core. Stop
Verify patch for system/extras
Verify patch for system/netd
error: patch failed: SoftapController.cpp:77
error: SoftapController.cpp: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/system/netd.git to /home/linmao/imx6/myandroid/codeaurora/system/netd. Stop
Verify patch for system/vold
error: patch failed: DirectVolume.h:27
error: DirectVolume.h: patch does not apply
Error! Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/system/vold.git to /home/linmao/imx6/myandroid/codeaurora/system/vold. Stop
Labels (2)
Tags (3)
jimmychan
according to the error message:  Can't patch from /home/linmao/imx6/imx-android-r13.4-ga/code/r13.4-ga/platform/build.git
seems the path is not correct. please try to put the imx-android-r13.4-ga in /home/linmao/imx6/.
jimmychan
