Hi all,
recently, I am using FRDM-KL05Z(not KL25Z) evaluation board to developing a project. When I enable interrupt in WWLU setting. it will generate errors when you try to compile it. I dont have this issue with KL25Z board. There are four errors
I copied the error:
Description Resource Path Location Type
Generator: FAILURE: at line 135: Incorrect expression, For input string: "" (file: Drivers\Common\SetRegBitMask.prg) EEPROM_KL05 Cpu Processor Expert Problem
Generator: FAILURE: at line 135: Unexpected char in bool expresion:-1)) (file: Drivers\Common\SetRegBitMask.prg) EEPROM_KL05 Cpu Processor Expert Problem
Generator: FAILURE: at line 156: Unexpected status, please contact Freescale support. (file: Drivers\Common\SetRegBitMask.prg) EEPROM_KL05 Cpu Processor Expert Problem
Generator: FAILURE: at line 2793: Unknown macro: "CPU_peripheralSpecLLWU_F2Reg" (file: Drivers\Kinetis\Kinetis.drv) EEPROM_KL05 Cpu Processor Expert Problem
Does anyone know how to resolve this issue?
Thanks in advance
Solved! Go to Solution.
please find the attached hot-fix. To apply it please copy its content over the MCU folder. The folder is located in the root directory of your CW installation. Please note that the hot-fix is only temporary solution. The fix will be published in the CW V10.3 production version. The release of this version is scheduled on the 7th December.
best regards
Vojtech Filip
Processor Expert Support Team
I have reproduced it and classified it as a bug in the latest version of PEx for MCUs. We are working on the fix of this issue and also preparing hot-fix for CW V10.3 BETA2 because there is no workaround.
Please use the Processor Expert Software forum for future questions/issues.
best regards
Vojtech Filip
best regards
Vojtech Filip
Thank you Vojtech Filip
It is fine now~~
I will download the new version in Dec. 7th
Thank you
