Error on i.MX53QSB FLT & 5V LEDs are blinking
LuisRivera
Hi, I want to know if somebody had experimented this issue.
I just introduced the SD card with the BSP of Windows compact Embedded 7 into the QSB and nothing happened even all LEDs were lit (turned on); so I decided to push the power button and sudenly FLT & 5V LEDs started to blink and the other LEDs turned off.
I took a look into the trouble shooting in hardware manual but there was anything related to this issue.
Does anybody know if there is a way to reset the board or something to solve this issue?
Note: It was the first time that I test WCE7 in the QSB.
jimmychan
Please try to contact Adeneo for support this QSB's WCE7 BSP issue.
Hi Adeneo Embedded, would you please help? Thanks in advance.
LuisRivera
Hi, I didn´t know exactly what happened with the QSB but few days ago I pushed the power buttom for 5 seconds to try to reset the board and It strated to work out; even WCE7 runed on the board.
thank you, regards
