checkers
Peripheral is already used ... USER - how do I remove ?
Discussion created by checkers on Nov 19, 2012
Latest reply on Nov 19, 2012 by checkers
I was learning the Processor Expert and defined MSCAN as used externally.
Then I discovered that was not the right way to do it.
Now, I want to add the MSCAN component, but it does not allow me to assign it to MSCAN because
Peripheral is already used by special signal USER (MSCAN controller)
I have looked for over an hour through help files, etc and cannot find how to remove the incorrect definition.
Do you know where I can find this to un-assign it from USER?
