The CodeWarrior Development Studio "Welcome" perspective layout (see attached image ),have an "Example Projects" option.
Can i get / download those "Example Projects" source code for enabling P2041 reference board design, beside the default "Power Architecture Project" ?
Thanks.
Solved! Go to Solution.
I think it's not an approach to get example projects, just telling you "Use the Eclipse Import Wizard to import example projects into your workspace".
For the P2041example, you can find some in NetComm Software.
Thanks for you replay.
Now i'm familiar with NetComm Software.
Is there additional P2041 examples available beside NetComm Software ?
