SDK crossscripts
SDK crossscripts
dan
We currently have two teams working on development for the P4040.  We are using two different compile machines.
What I have found is that when the they ran bitbake fsl-image-full the following file was modified with their paths
build_p4080ds_release/tmp/sysroots/p4080ds/usr/bin/crossscripts/powerpc-fsl-linux-libtool
On the build system that I am using, no matter what bitbake recipe I use, this file never gets modified.  All of the paths are prefixed /home/jenkins.  We are both currently using SDK 1.2.1.  Any thoughts on why this file is not getting modified?  I am getting ready to manually edit it.
mattsm
Are you both using the sstate-cache provided ISO?
-M
