Need help here. I am new to CodeWarrior, I am facing
Link Error: L1119: Vector Allocated at absolute address 0x3FFD overlaps with sections placed in segment, absSeg176.
I am using c programming and MC9RS08KB4CWJ. Please help, thanks!
Solved! Go to Solution.
Hello
It looks like you have defined a interrupt function with interrupt <vector_num> somewhere in your application and you have also define an interrupt vector table.
The two definition are overlapping.
Please open your .map file in an editor window and check what is allocated at address 0x3FFD.
In order to remove the message remove the vector number next to the interrupt keyword.
CrasyCat
Yitlilee, did this resolved your problem?
Please let us know!
Thanks! :smileyhappy:
Yes, problem solved. Thanks for Catherine
Hello
CrasyCat
