adv7180 capture result is not right.
Question asked by Gao Jianzhong on Nov 13, 2012
Latest reply on Nov 27, 2012 by rogeriopimentel
Branched to a new discussion
I am using the imx53 AI board to capture NTSC input from adv7180.
And i use the default linux BSP.
But when i run the /unit_test/mxc_v4l2_tvin.out,
I get the wrong result.
The right result is all color is yellow.
but the out put on display had 4,5 vertical green line。
I attached the file, is there someone have any ideas about this?
I think this is a problem of adv7180  output.
Thank you very much!
