ltib and fsl-mm-codeclib configuration
Question asked by Mach Lee on Nov 11, 2012
Latest reply on Nov 14, 2012 by Mach Lee
Dear All,
I have got a problem while setup ltib like below.
I'm trying with I.MX53 QSB (aka loco).
Please help me if any hints...
Processing: fsl-mm-codeclib
Build path taken because: no prebuilt rpm,
Testing network connectivity
OK GPP:
Try fsl-mm-codeclib-2.0.3.tar.gz.md5 from the GPP
http://bitshrine.org/gpp/fsl-mm-codeclib-2.0.3.tar.gz.md5:
23:01:09 ERROR 404: Not Found.
Try fsl-mm-codeclib-2.0.3.tar.gz from the GPP
http://bitshrine.org/gpp/fsl-mm-codeclib-2.0.3.tar.gz:
23:01:10 ERROR 404: Not Found.
Can't get: fsl-mm-codeclib-2.0.3.tar.gz at ./ltib line 790.
f_buildrpms() returned an error, exiting
traceback:
main:560
