Hi all,
Does anyone know how to use flash memory emulate EEPROM? if yes, could you provide sample code tutorial?
Thank you
Solved! Go to Solution.
You can download our flash drivers for EEPROM emulation in Non Flex NVM memory for Kinetis and ColdFire devices:
TFS Flash Driver Software for Kinetis and ColdFire+ Microcontrollers
If you are looking for EEPROM emulation using Flex NVM memory check the following App Note:
http://cache.freescale.com/files/32bit/doc/app_note/AN4282.pdf
Thank you for the information.
Does the driver support Kinetis L family? thank you
Yes, you can even find an example in the installation folder of the C90TFS driver.
(Installation path)\Standard Software Driver vBeta033\C90TFS\Demos\L2K
I'm not pretty sure however the flash routines should be identical, so most likely yes
